Fibrebrush cityscape
You can achieve some interesting effects using the fibrebrush. Just imagine if you could choose the shape of the fibre to an alpha shape!
pretty kewl, do you have any mini tutorial on how to go about creating something like this. Looks almost like a filter…very nice work…I look forward to hearing more about this technique of painting. :+1: :+1:
This is very fascinating. It looks like a mosaic. Really well done. You must have used a large fibre setting for the brush to get the square tile effect you have there.
And you are right, there would be endless possibilities if you could us an alpha to shape the brush fibres.
Neat & original!
Hi KenH
You have re-discovered the technic of a french old master painter Seurat “pointillism” :slight_smile: http://cgfa.sunsite.dk/seurat/
Bravo !
Can you explain your technic ?
2 layers ?
You can choose a shape for your Fiber brush !
Just take the spray as Stroke !!!
Pilou
That’s a pretty cool mosaic effect you’ve created there, Ken. Interesting technique. :+1: :+1:
I whipped up a script for yous! :slight_smile: But I can’t figure out how to change the shape…any explanations?
Mosaic.txt
Hi KenH
In fact I don’t success to load a form on each fiber of Fiberbrush with spray (exept the shape inside the fiberbrush tool) :frowning:
Just the shape of the flood of fiberbrush :slight_smile:
It’s not so bad, with one clic you can make a multistars’sky :slight_smile:
I think the only solution is the Spray alone ! With it you can choice any shape !
But you will not control the “superposition” of this forms see my link : (2 pages)
http://www.pixolator.com/zbc-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=009619
Have fun Spraying
Pilou :cool:
Ps I have seen your script. Great !
Why do you make 2 pass with little points form before use the rectangles ?
See another of my post :slight_smile: :slight_smile: :slight_smile: Cities too :smiley:
http://www.pixolator.com/zbc-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=009495
Similar technic indeed :slight_smile:
After seeing your work with the spray brush, I had to go try it myself. This is a 10 minute doodle. Sorry about the white dots, I didn’t realise until after I was done that I had the wrong material on (white plastic). Oh well this is just for fun anyhow.
The Hut
:b2:
Nice work guys. :+1:
Frenchy: I could say I was demonstrating different strand thickness…truth is I made a mistake! :wink:
Hi KenH
It’s nothing, supense was more intense :smiley:
Pilou
