If been workin with fibermesh which is awesome. But my problem is no matter now thick I make my fibers while I’m working, when I do a BPR render, the fibers are still the same size. How do I affect the size of my mesh in BPR like preview?
In ‘Tool > FiberMesh > BPR Settings’ is the ‘Radius’ slider set to at least 1 or higher?
Can that be changed after the fiber has been created/accepted or do you have to make that adjustment when creating new fibers? I have eyestrain from looking for that setting, but am not seeing it anyplace here. Thanks in advance.
You can still make the adjustments after you have accepted the FiberMesh. Any adjustments you can’t make will be grayed out in the FiberMesh subpalette.
I thought maybe you’d post an image of it outlined in said panel. Found it. Once you accept, that’s it. No edit possible.
Once you ‘Accept’ the FiberMesh, it becomes it’s own subtool. Select that subtool and the FiberMesh BPR settings will be back.
Thanks for your assistance, I need all I can get.
It’s not very good forum etiquette to come into somebody else’s thread and start making it your own.
@zber2. You are correct, my bad, I fixed my post, but I can’t edit your post, so the reference remains? I guess you didn’t get my PM.
