hi!
I´m wondering if exist a way, maybe via zscript, to grow fibermesh one strand for each mesh vertex.
is this possible?
Dunkel
hi!
is this possible?
Dunkel
You can set the number of fibers to equal the number of points - simply set the MaxFibers slider to equal the number of points. (The slider value is in thousands, so for 4000 points you would set theslider to 4.) But you can control exactly where the fibers are - they will be scattered over the surface in a non-uniform way, depending on the other Fibermesh settings.
If precise placement is important then you might achieve what you want using Micromesh instead.
