Hi.
Is there a way to use fibermesh as an insert mesh brush?
Actually the main idea behind this, i would like to use the insert mesh brush curve tool to create my guide hair curves.
But if iam using polygones then i can`t convert them into curves easily, but if i would just use a single fibermesh i would be able to export that as my guidecurve later.
Also, does anyone know the shortcuts for the insert mesh curve tool? What would be the right key to create a new curve?
Right now i am pressing “5” which does a snapshot? Is that correct?
Also, is there a way to edit previously painted curves?
Thank you very much in advance
