Hi everyone,
I’m fairly new to ZBrush, so please excuse if these requests have already been covered in the past. I’ve got two suggestions:
add a make planar funktion to the poly menu of ZModeler, with options like using the averaged normal of the polys selected or the normal of the poly the user is clicking on to evoke the action. I’m aware that you can use the clip curve brush to similar effect but I’d still love to have something like that in ZModeler.
Same goes for an extrude / qmesh option that will not scale the extruded polys but simply move them. (e.g. when you qmesh on a sphere)
The other request is an addition to the UI. Ii would be great if you could add a calculator interface to the numerical input fields. With all the new Cintiqs / Mobile Studios coming out, I imagine a lot of people will want to use smaller, portable keyboards with number pad or possibly not use a keyboard at all. A little calculator style pop up that let’s you input the numbers like on a touch device might be really helpful. Even better if you can actually use it as a calculator.
Cheers!
Jens
