I think the biggest feature by far I find myself wanting is some kind of merge similar polygroups tolerance feature.
So often I will use sculpris pro or something out that will just create LOADS of little stranded islands all over the place that I need to tidy up so that I can cleanly zremesh.
I find the merge stray/similar options never catch enough of the stranded groups. I know there are little tricks to clean things up, but I thought -if only there was some way of adjusting the tolerance of those options that would be SO cool. ie. If I up the tolerance, it would search a wider range for similar groups to merge with - or something to that effect.
I know im probably simplying the technical challenge somewhat - bit im sure something would be possible to up the reliability of these tools
thanks for reading
