FBX export to Toolbag
The camera imports well but the focal length differs (30 in zbrush is 32,15 and the field of view value is way different. Also renders doesn’t match up or I didn’t have a luck)
If you manually adjust Toolbag to 30, you have same view. Still, you would have to manually line up both renders.
I think the camera needs to be moved as focal length changed but It’s hard to guess by how much.
It sure needs more investigate but it’s how it works for me.
I have the same issue between Maya and ZBrush. This is what it looks like in Maya compared to ZBrush
