Failure to load Brust tool preset.
Hi there, i just installed a zbrush 4r7 and 4r8 and when i was about to load my imm brushes which i bought these errors popped up. This was working before on 4r7 but suddenly it doesnt work now. The file loads on 4r8 without errors but it doesnt work properly. I cant access the brushes inside the imm and when i drag them out the appear as circle mesh only. I did some research with no luck on this. I bought several kitbash kits and only kits from kitbash3d works. Most of my brush works before the new versions.
up
The newest version is ZBrush 2018.1. Maybe you should consider upgrading to the newest version. The upgrade is free to all registered users. If you don’t want to do that , then you should submit a ticket to Support.
