Face in 3D with profile portrait and side pictures?
Can Zbrush create a 3D mesh and a rendered 3D face, with my own profile portrait and side face pictures? Including my skin texture?
no :slight_smile:
you would have to sculpt it and to texture, you can just load them as reference for viewing.
Shadow Box can help to create rough silhouettes, but this is in this case no solution.
There is no 3Dsoftware in the world, that does things for you just from loading up pictures.
What you are seeking is photogrammetry… and on these raw results of photogrammetry you can work then in zbrush to get the best out of it.
Thank you for approving the post and replying to it.
Would you mind if I asked you another connected question: Which photogrammetry application package do you propose? I thought that the extraction of 3D data from images was possible in Zbrush.
Thank you once again.
Agisoft is the standard application and affordable.
Reality Capture is also good (some say sometimes better) but much more expensive
Good luck…
Thanks once again for replying.
Regards
