Most of the time when I’m extracting subtools from a model’s surface, I want to extract from that surface, not have the surface of the object be the mid-point.
For example, if extracting something intended to become clothing, I don’t want the clothing to intersect with the body, I want it to lay on top of the body…but it appears there is no control for how much you want to extract inward or how much you want to extract outward…?
The only workaround I’ve found is that you can extract a subtool and then use deformations to inflate and/or scale, but it isn’t very precise.
Am I just missing a simpler solution (hey, it happens!)? Anyone else have this issue?
And one more thing…is it just me or is the thickness amount setting a little too ultra sensitive (0.01 for cloth…0.03 for leather…)? We’re dealing with 10ths of fractions here and numbers that don’t really appear to mean anything… (it’s ok, you can say it’s just me if it is!)
