Exporting high resolution images
Is there is any way to export documents as a psd with a higher resolution? When I export the PSD and open it in photoshop, it’s only 72dpi. Any way of changing it to 300dpi?
Ok thanks for you time guys!
Javier Loredo.
ZBrush only exports at 72 dpi but in photoshop you can easily change that without affecting the quality.
In Photoshop load your picture and select Image > Image Size. Deselect Resample Image and adjust Resolution to the desired dpi (pixels per inch is the same, ppi).
To print something at a certain size or dpi you need to calculate the required canvas size needed in ZBrush. Pixolator wrote a little zscript to do just that. DPI ZScript - A Document-size & Print-size calculations + Print-size preview…
