I’m creating normal maps in ZBrush using the normal shader. When I export it gives me two options PSD/TIFF. Exporting both gives me 8 bit per channel.
Any way to get ZBrush to export at 16 bit per channel?
Thanks,
-= Dave
Thanks,
-= Dave
No, ZBrush doesn’t support RGB maps of 16 bit per channel (other than displacement maps).
Is there any way to write a plug-in or any good way around it?
8-bit normal maps can significantly reduce the quality of surfaces with more complicated BRDF’s.
Not that I know of, though perhaps it would be possible to write a converter for a displacement map.
Are 16 bits per channel normal maps used much? I’ve not heard of it.
I could certainly write a converter for a displacement map but calculating a gradient from a height field will produce different results from directly outputting a normal from a surface. I’m not sure how bad it would be though and if it’s our only option then I may have to do it.
It’s not too common and it depends on the studio and how much they care about their renderer. I know a few game studios and film studios that work with it. We’ve been converting over our texture authoring pipeline to be completely 16-bit depth for colors and normals.
I suspect it will start to be more common in the near future. At siggraph this year Crytek was showing off the errors and popularizing the idea of 16-bit bit normal maps.
-= Dave
Your first message suggests you are using the canvas for normal maps. If so, you might try zscripting a solution. It’s possible to get the normals for each pixol using the PixolPick command. The values returned are floats though I don’t know if there’s actually the precision to benefit from 16 bit channels. The method is a little slow but may be useful.
[Loop,document:width,
[Loop,document:height,
[VarSet,xNormal,[PixolPick,6,xPos,yPos]]
[VarSet,yNormal,[PixolPick,7,xPos,yPos]]
[VarSet,zNormal,[PixolPick,8,xPos,yPos]]
//write values to image block
,yPos]
,xPos]
