export texture larger than 1024 ?
is it possible like with advanced alpha exporter to export textures larger than 1024 dpi? I would desperately need a resolution of 4096 dpi but I can´t find any settings within the texture menu.
if resolution can´t be changed in zBrush there´s maybe a plugin somebody knows of…
solution is to blow your document up to a resolution of your needs and fill layer with the texture. then do a GrabDoc from the texture menu. this stores another texture with the new resolution taken from document size.
You can also export the blown out texture to keep that saved, inorder to use again.
Its always best to create a new texture of 4096 dpi before painting in PM then blowing it up later.
Displacement Exporter uses whatever size the displacement map was created at. So you would set the size that you will want your map to be by adjusting the Tool>Displacement>DPRes slider. This allows you to create your maps up to 4096x4096 in size, which Displacement Exporter will then export.
