Does anyone know of a way to export a noise maker pattern as a texture file by itself? I figure I could apply it to the mesh, then export out a displacement map, however I just want the pattern itself as it appears on the mesh uv layout. Once I have the pattern, I want to use it for blending into my texture map as well as using it as a separate specular map.
Any help is appreciated!
