Export\Import all the settings From r7 to r8 (Need a help)
Hi all.
I Installed r8 on top of the r7, but I see Default interface.
How can I save all the settings from r7 and import them to r8?
Include brush tool panel, plugins, startup and my HotKeys
I probably need a plugin or script for this?
Unless you’ve uninstalled 4R7 you can simply copy over any custom materials, brushes etc. As ZBrush 4R8 is only 64 bit it is installed in Program Files>Pixologic not Program Files (x86)>Pixologic.
For a custom interface, the advice is to rebuild for 4R8. This is because of technical restrictions due to the language changes in 4R8.
Thank you.
