In my workflow I am quite used to exporting images from ZB (Document / Export) and never had a problem. Today this is not working! Hopefully I imported the below screenshot in at a size for you to see properly. The red arrow and circle pinpoint the problem; the OK and Cancel buttons are almost blacked out and DO NOT WORK! From this point on the only choice I have is to hit Escape to close the window and get back into ZB. I have tried restarting the programme twice more, both imported tools and started with a clean mesh. Nothing I do will let me export an image.
Now, I should add that Windows performed an automatic update a couple of days ago and this is the first time I have tried to export an image since. Coincidence? Maybe. I have no idea. I’ve searched the forums but no-one seems to be having this problem. Anyone care to give it a try if they are on Windows and have had an update recently?
EDIT: Went back to try and solve this and discovered the problem. When ZB is full-sized in window the OK and Cancel buttons are hiding behind the Windows Taskbar. They should still work because I technically can still click on them - but they don’t. Can’t remember if this was the case before Windows update. Anyway, as a workaround I can minimise the window in order to “enable” the buttons. Very odd…
