every time I save my file I should choose path
Here’s the project now I’m on.
each of time when I save my project. I should choose save path everytime even I already save it like a save as other file… It’s some time annoying and I want to fix it.
How can I do for it? I hope I can do something for it.
Thanks!
Yes it would be nice to just hit Save and the project did it without the prompts. This was asked about before and I don’t remember if anyone had a solution.
The only way to avoid it is to use Quick Save.
thanks marcus!
Thanks Dillster! I hope I can adjusting to this…
Yes the Quicksave will work, 9 is the hotkey for it. You can then find the saves in Lightbox>Quicksave folder. In Preferences, you can set the number of Quicksaved items so you don’t end up with too many.
Google “Nicks Tools Zbrush”. His plugin lets you set a zpr file you want to save, and then has a save button like in photoshop or Maya. It can also increment your save as axe_1.zpr, axe_2.zpr etc.
I’ve learned to really enjoy quick save lately. If I’m about to try something uncertain I just quicksave and try it, then move on.
I had the same problem and incidentally found that hidden button.
Since that it is much easier.
damm Alexx!! Thanks so much!!
