Error messages when making scripts use to appear broken, like this:
Has this a solution, or does ZBrush have an error log for this somewhere from which to read the full text?
Thanks!
Thanks!
hi @Jordi_R_Cardona ,
it just mean you are passing not enought parameter when you call your routine, or it also can be a syntax error.
[routinedef, sum,
[varset, result, a+b]
a, b, result]
[VarSet, result, -1]
[RoutineCall, sum, 5, 10]
the routine need 3 parameters/arguments then you just pass less than the minimum
so in my code i only pass two parameter a and b, but not result.
proper code would be :
[routinedef, sum,
a, b, result]
[RoutineCall, sum, 5, 10, result]
if it’s not that, then it probably a missing ].
Hope it helps!
Nicolas
Sorry maybe I did not explain well. Your explanation is very good, but I was not asking about what that error means.
It was just an example. The problem is that I can’t read the full error messages in general.
I mean, that at least in my computer, the error messages appear truncated:
“the number of inputs…”
and you can’t read the full phrases.
So sometimes it’s hard to know what is the error.
Is there a way to read the full phrase and info of an error, or there is an error log file somewhere?
Thanks!
then i would say welcome to Zscripting where the grass is green but the error messages are trunky
Ok lol! Well, no worries!
