Hi Peeps,
Since having ZBrush 4 I started seeing the following error message when importing Wavefront .obj: “Error Encountered While Importing a File”.
I’m trying to import geometry from Rhino V4 (which I have had no problems with in the past, until upgrading Z Brush). I don’t want to sculpt the imported geometry, instead I need it as a scaled framework, to build my Z Brush elements around. I’m working in manufacturing, so I need to mix organic parts with tolerance, structural ones.
My work around at the moment, is to take a render of my structural geometry and use the image planes to guide me. However, this is not ideal and quite frankly a rubbish ‘make-do’.
When creating the .obj I have tried “export .obj” straight off the NURB geometry. I’ve also tried converting the NURB geometry to a basic MESH and quadrangulated it (as I know Z-Brush tends to be happier with quads than triangles). I’ve then exported the clean quadrangulated mesh as an .obj.
Hope you can help! ta
