Erreur avec Spolight et texture
Bonjour, j’ai importé une texture puis activé le spotlight, j’ai ainsi pu mettre à gauche une référence, mais impossible de modifier l’objet, on dirait que le spotlight bloque la modification. Que fais je de travers ? Merci pour votre aide !!
Turn off “Spotlight Projection” in “Brush > Samples”
Hello, thank you for your precise answer!! I wonder what this “spotlight” function can be used for? I may discover this in my online courses, but I’m surprised that on one side you can “activate” it and elsewhere disable it. But I don’t know Zbrush, there must be his reasons. In any case thank you very much! Protect yourself!
@fl0645
If you want to use textures to polypaint your model, then you will have to turn on “Spotlight Projection”. This is shown in the video below. If you just want to use Spotlight for reference then you will have to turn it off.
Thank you so much!! I just realized the power of SpotLight!! I didn’t understand everything, but indeed when it is active, it is super effective, apparently, still to be learned!! Thanks for the link!! see you soon!!
