Hi, noob here. Is there a way to erase an alpha from a model? Thanks.
Hello!
If you’re talking about an alpha you just applied, you can ctrl-z. If undo is not an option, and the alpha has been stamped into the geometry, then you will have to smooth or otherwise sculpt it away with ZBrush’s brushes.
Thanks very much for the reply Spyndel. Yes, Ctrl+Z was not an option.
