So it used to be that in zbrush 4r2, if I added say… A ploymesh 3d ring, i could click on the initialize button and change the inner ring size, the resolution the outer ring size etc, it appears this initialize oprion has been totally revamped to do something else, and now im stuck with how I am supposed to edited my Polymesh 3d. What is the new way to do this? I hope my question makes sense.
It is still there for me, although you only have the primitive initialize menu when you select the primitive by itself, if you append it to your other tools then it automatically becomes a polymesh3d.
What bersion of zbrush do you have, I am on 4r7.
same as you, windows
i noticed you said “add a polymesh3d” that might be your problem, as i said you can only initialize when you choose a primitive separately from your normal poly3d tools, the second you append it into your subtool menu it will become a polymesh3d or (pm3d_ring etc) and you can no longer adjust it in the initialize menu.
