editing imported object
Hello,
after importing a OBJ file, i started editing it, but i noticed that the x-symmetry
is not good. If i start on the left eye for instance, i also edit the right ear… so it is a bit out the centre. How can i adjust that ?
Tnx
Joe
It’s possible that your model imported with some kind of positional data that kept it from being centered when it was imported. Try pressing Tool>Deformation>Unify.
If symmetry is still off, then try using the ReSym deformation.
Also, bear in mind that your model must be symmetrical to begin with. If it’s already posed, for example, then symmetry won’t be possible.
