Editing a tool in wireframe mode ?
I would like to edit my model in pure wireframe mode, I need the wireframe to be straightforward (transparent, thin and with minimal/no blur) like in other programs.
  • clicking the dots display function in the transform palette has no effect
    – same with the point selection mode function
the show poly frame function works however it has colour and the “wire frame” line is thick and aliased/blurry.
Just go into lowest subd and edit the existing topology.
You can change the settings of the polyframe in the Preferences / Draw subpalette. If you add a plain white texture to your tool you won’t then see the polygroup colours, just the base material.
I would like to see the polygon frames of multiple selected subtools at the same time, is this possible? (just being able to see multiple subtools at the same time is not enough for my current project)
Using the framer01 material I get a faint grey line for other subtools… and a black one for my active subtool, this might be enough… I’ll continue playing around… but please let me know if there’s a better way.
