Edit mode disabled?
I ran into some trouble recently when trying to load a tool I am working on in Zbrush. When I open Zbrush and click “load tool,” I can only drag it around as a brush. Pressing the “T” key to switch to edit mode doesn’t resolve the problem as the edit button is greyed out and I can’t switch.
Image: http://i.imgur.com/kn0o1CA.jpg
I am thinking that the problem is with my tool itself as I can load in other ZTLs and edit them normally. How can I re-enable the edit button to resolve this?
You should upgrade to P2. Note your stroke type. Switch to DragRect, then you should be able to switch to edit mode after drawing. :wink:
