Hello
I use the Cintiq with Zbrush2. When I am in edit mode of an object, the edits to detail that I try to make with my Cintiq pen are not smooth lines. If I had a sphere or a cube and I try to sculpt on it, the changes that I make come as “dot dot dot” in a series, not as one smooth line. The alpha is on regular default. I must move very very very slowly to get a line and then it is lumpy not smooth. What is wrong? I can use smooth sometimes (with shift) to help with the lumpy edits a little. But I cannot make fine detail in sharp lines as with wood grain because the line goes “dot dot dot”. What is wrong?
Thank you!
