Hi I want to solve this problem can help somebody?
Locate problem areas and uncrease them.
You need to put a crease on the bottom blue edge for it to hold the square shape, if that’s what you’re aiming for?
No Iam looking to remove those bumpiness on the bottom and under that edges
and I cant use insert edge loop under it because it will destroy the cilender shape that it has
If I insert edge loop under that it fix the bumpiness but it will create a little hard edge something like smooth creasing (second pic
