I was putting updates to this collection of Zscripts in the “Useful small Zscripts and Macros” thread but I kinda felt like I was posting in there too much so I decided to make a new thread for this Zscript.
Anyway, Here is my link to the latest pass on a collection of small Zscripts that I’ve been working on.
http://www.ericblondin.com/p/download.html
Just click on the “Download - E Tools.zsc v1.4.4” link at the top of the webpage in the above link and then simply extract all of the contents from the .zip into your ‘C:\Program Files (x86)\Pixologic\ZBrush 4R7\ZStartup\Zstartup/Zplugs’ or ‘…Zstartup/Zplugs64’ folder. Then when you run Zbrush you will see a “E Tools” panel under Zplugin, where these scripts reside.
The above link also has a short description of each command inside of E Tools.
This grouping of “E Tools” replaces all other previous Zscripts (“Zplugin > E”) that anyone may still be using by me.
Big big thanks goes to Marcus Burgess (marcus_civis) and Nick Miller (Nyx702) who helped me out a TON on many of these scripts!
Please test it out and let me know if you have any suggestions or issues!
Biggest updates since version 1.4.0:
- Switch buttons replaced regular buttons on several different commands to make it easier to see if the command is active or not.
- Sped up several of the commands. Some of them now run over twice as fast.
- Merge UV - Toggles ‘Tool > Subtool > Merge > UV’ on all subtools
- Merge Weld - Toggles ‘Tool > Subtool > Merge > Weld’ on all subtools
- Various bug fixes
