I noticed that it is possible to dynamically rename UI buttons through commands in the ZFileUtils. However I have found myself in need of Adding or Subtracting UI buttons and I’m not sure if this can be done…
Basically my script needs to crawl a specified directory and create a UI button for each OBJ found within that directory (it would also rename the UI button to the title of that same OBJ).
Preferably I would create and destroy buttons accordingly but if this is not possible I could always hard code say 100 buttons and then rename them after crawling the directory, this would leave me with a large number of unused buttons which need to be hidden so that the UI only shows Buttons tied to an existing OBJ.
Any Input on this would be greatly appreciated!
