Hi there,
Maybe there is some way to remove the dynamic subdiv warning so it dont appear anymore neither once?
thanks a lot.
Hi there,
thanks a lot.
hi @joaovictor3d , welcome on ZBC!
Can you tell me what you are doing to get the warning message that dynamic subdivion is turned on ?
So the only way to do that is to make a macro and use that macro to remove the warning message that popup, but if you want me to make a macro i need to know what you are doing to get that warning…
Best Regards,
Nicolas
Hi, thanks for replying.
This is that common window which pops up when you turn on dynamic subdiv for the first time after start zbrush. So you can choose to “always yes”.
So I would like to never appear that. Is it possible?
thanks Nicolas.
Sorry to get back to you so lately i had been busy.
So when you press the D hotkey which by default is the hotkey to go to the higher res subdivision.
If the active subtool has no subdivision level and you press D key, then you can’t to go to the higher res mesh.
what are you trying to do by pressing the D hotkey ?
if you want to a classic subdivide then the hotkey is CTRL+D and not D.
Otherwise if you use that hotkey to enable the dynamic subdivision, then you can assign a hotkey to the dynamic button of the dynamic subdivision section, there is no popup.
Hope it help!
Nicolas
hey! thanks a lot for replying…
I am just trying to disable this warning, because I have been using dyn subdiv a lot, so if possible would like to “press skip the warning forever” hehe
