Hi guys
Here i´m sharing this little couple of buttons called DynB On and DynB Off.
I was tired of failing when trying to deactivate dynamic on the Brush size slider tiny text while pressing Shift. So i decided to ZScript those buttons.
I tryed to create a switch button for this purpose. The problem i found is that Zmodeler always change to dynamic and i can´t manage to update the switch button status for that case. So some times the switch button needs to be pressed twice and does not represent the actual status of the brush.
I thought the simplest solution was to make 2 buttons On and Off so they never fail when using a hotkey or a custom UI buttom.
You can download and watch the buttons in action here
HTH
