Hi All,
My first post, hoping someone has some ideas.
I use zbrush to produce models for rping. I always have trouble converting nanomesh tools to a dynamesh even when keeping the original nanomesh tool to a small poly count. Is there a workflow to get that repeat pattern dynameshed. Or a way of converting all the tools to a water tight mesh. I love how easy dynamesh generally sorts things out but the one gripe is that it can get very pixally in creases unless you really bump up the poly count and then remesh after.
The dynamesh either crashes the program or the the results are shredded as below
Thanks in advance
T
