Hi guys,
I have a problem about dynamesh workflow. I don’t know if I need to keep dynamesh on until the final resolution and details or Dynamesh is just for making the base mesh and I need to turn it off when I pleased with the base mesh so as to add resolution and final details.
I’m aiming at rendering the sculpture using Vray and 3ds max so I confused about the workflow. Which one would you recommend:
- Exporting a high detail model from Zbrush into 3ds max and render it using Vray proxy.
- Exporting displacement and normal maps from Zbrush and applying it to the base mesh in 3ds max.
Thanks.
