Dynamesh won't remesh...
:confused:Hi to all.
Have a dynamesh issue. When I go to remesh, hold ctrl+click drag I get the masking pen and nothing seems to happen?
What am I doing wrong?
Have you made any changes since the last time you re dynameshed? Unless you’ve dones some sculpting, even a little bit of smoothing, it won’t remesh, even if you change the resolution.
Seeing the masking marquee when ctrl-dragging in empty canvas space is correct. Note that if your object was masked you must repeat this procedure twice–the first time to clear any masking, the second time to intiate the remesh. Obviously Dynamesh mode must be active.
Otherwise, bear in mind Gordon’s point.
