why dose dynamesh resoultion slider change into a skin resoultion slider on custom menus
here is whats happens
first when i start zbrush and drag out a primitive hit t to go into edit mode
then turn it into a polymesh3d
my dynamesh resoultion slider on my custome menu is fine
now if i hit t agin to go out of edit mode then pres ctrl + n to clear my canvas
then drag out another primitive hit t to go into edit mode
my dynamesh resoultion slider on my custome menu has change into a skin resoultion slider
why
also if i add
these buttons from the transform menu
activate symmetry
x
z
y
activate radial symmetry
radial count
then show up nicely just like dynamesh resoultion slider at first
then after that at the same time the
all those symmetry tools disappears from my custom menu
now all those buttons still works fin if i use them by going to the transform menu
also the dynamesh slider works fine if i use it from its default place under
geometry tab then dyhnamesh tab
also another way to fix this issue
is if i load my cfg again then my custom menus is fine
or it is like it was when i first launched zbrush
if i drag out a primitive and make it into a polymesh everything is ok
second time i do that
and all my symmetry byttons i listet are gone
so whats up with this
it happen both in zbr7 and zbr8 ???
