Hi guys
I am trying to use dynamesh but I cant get enough resolution. I go up to 4096 and and still the resolution is the same as I am at 1024.
I tried resizing the object but this doesnt help. Do you know what is the problem?
Thanks in advance.
I use the Dynamesh master plugin:
http://www.zbrushcentral.com/showthread.php?177194-DynaMesh-Master!-unofficial-Information-Installation
It allows you to set the points that you want, and generates the dynamesh for you.
Thanks very much Thor. I really appreciate it.
No problem…
One thing that’s not immediately obvious about the plugin…
After you run it, it will set all the dynamesh options… but you still need to click on the Dynamesh button to activate dynamesh.
Cool. Thanks again
