I’m still not able to use insert meshes to subtract when using this plugin anyone else?
EDIT: Found a workaround. Once it’s done its dynamesh where it bases it off polycount. You then activate normal dynamesh (from the geo tab) and do the subtraction. Then just for good measure redynamesh with the plugin. It’d be nice if it activated regular dynamesh after you set the polycount, that way you don’t have to go and manually hit the button everytime you want to do a subtraction.
