When I’m using Dynamesh, occasionally it will get “stuck”, and will not change the resolution. For example, if I’m at 64 then I go to 128, it may get stuck there and will not update to 256, 512 etc. It also will not update down to 64 or 32. I’ve tried both the ctrl +click and drag method, as well as manually clicking the Dynamesh button on and off, but either way the resolution stays the same, and there’s no “updating…” message.
I find this to be odd, since I haven’t read of anyone else having this problem. Is it possible I inadvertently hit a button or clicked a setting that’s causing this?
), you need to make a small adjustment to the mesh for it to update after changing the resolution slider.
