I may have found a rather serious bug in ZBrushCore: the Dynamesh resolution limit seems to lower when handling complex meshes, specifically humanoid meshes. Here are the steps to recreate the bug:
1a) First, let’s prove that Dynamesh is working properly on simple meshes, just to prove that ZBrushCore isn’t totally bugged. Open ZBrushCore and open the Dynamesh Sphere 128 default project. Turn on Polyframe (shift + f) so you can see any resolutions changes. Turn Dynamesh to 256. Sculpt on the mesh a bit and retopologize (ctrl drag on the background). Your ZSphere should now have about 4x as many points. Good, it’s working.
1b) But let’s make sure it’s working at the higher resolutions. Turn Dynamesh to 512, sculpt on the mesh, and retopologize. Did you get 4x as many points again? Good. Now turn dynamesh to 1024, sculpt on the mesh, and retopologize one last time. Again, do you now have 4x as many points? Awesome! Dynamesh works just fine on simples meshes.
2a) Now let’s try that on a more complex mesh. Open lightbox, and open the DemoSoldier project. Make sure you’re working on the DemoSoldier subtool, as that’s the subtool that looks humanoid. Now, solo the subtool, 'cause the soldier’s body is the only subtool we’ll be playing with.
2b) Now to Dynamesh. Turn off Dynamesh projection, as that will speed up our test. Then turn on Dynamesh. Should work fine so far. Turn up Dynamesh to 256, sculpt a bit, then retopolgize. Should still work fine, you’ll have about 4x as many polygons as you did before. Nice. You’ll probably have around half a million polygons. (I have a little over 600,000 right now.)
2c) Now for the bug. Turn up Dynamesh to 512, sculpt a bit, then retopologize. The points will move around a bit …but the total number of vertexes won’t significantly change. You’ll still have around half a million polygons. Just to test it a bit more, turn up Dynamesh to 1024, sculpt a bit, then retopologize. You’ll STILL have around half a million polygons. When working with a sphere, we could have any level of detail we wanted. When working with a humanoid, we’re stuck in the half million range.
3a) Let’s make sure the bug has to do with humanoid shapes, rather than some other factor. Mask the soldier’s chest from the rest of the body: no legs, no arms, no head. Then, go to the Subtool menu and “Split Unmasked Points”. Now we just have a chest, really just a block kind of similar to that old Dynamesh Sphere. So, retopologize. If you’re still at a resolution of 1024, you’ll jump from less than 200,000 points to having over 2 million.
So, have a found a bug in ZBrushCore’s Dynamesh? Did I find a feature? (Is Core’s Dynamesh supposed to have a hidden limitation?) What’s going on?
Thanks,
–Saib
