Dynamesh and UVMap question
Hi everyone,
I'm working on a tutorial for beginners and a couple of question have come to mind that are causing me a minor issue.
Firstly I have a model with 3.6 mil poly’s. I can’t use Dynamesh on this item as nothing happens for some reason. ! I use make polymesh and then Dynamesh and this brings the count down to 1 million poly’s.
Q. 1, Why isn’t dynamesh affecting my model. Any ideas please.
Q.2 Even with a 1 Mill poly model I’m can’t use the PUVTiles on 2048 which it should be able to handle 1 million poly’s, why is that. ! but does work at 4096(wasteful I understand)
Anyone please give a few hints as to how some of these issue can avoided or corrected , thanks.
Rachel.
This might help. You were a bit vague… http://docs.pixologic.com/user-guide/zbrush-plugins/decimation-master/
Thanks for this, Sorry for being vague, it was not intended. Your help has solved the issue about not being able to apply the PUVTile map at 2048. I have no idea why the 1.1 mil poly would not be accepted but 600K certainly does.
Thanks again, much appreciated , I can get to my beginners tutorial now. :slight_smile:
:+1:small_orange_diamond:+1:small_orange_diamond:+1:small_orange_diamond:+1:small_orange_diamond:+1:small_orange_diamond:+1:small_orange_diamond:+1:
