I’m trying to set something up using the new droplists, and I’m stuck on understanding exactly how they relate to the memory blocks (as used in the ZFU example).
I switched a couple things around, but it’s basically the same. I want an ADD to list button, and the list itself (selectable).
what I’ve noticed however, is that when I use ZFU_DropdownGet, I don’t seem to get the correct corresponding string name for the list item index that I would expect. It seems to get out of sync with the current index somehow, and I’m not sure how to make sure that I always retrieve the correct corresponding string name associated with an index.
It’s rather hard to explain, so I’ve attached an example, with a “Get Info” button that reports on the active index, corresponding string name, and the current MB string setting.
How did I not see that, it was working all along, and my debug button had a bad variable. That was totally it. Thanks for the save again Marcus!
