Drawsize not working any more... [Answered]
Hi Everybody,
today i encountered a very strange Bug in ZBrush 4R2. I can’ t adjust the Draw-Size anymore.
Even after Rebooting my System and “Initializing” ZBrush i couldn’ t adjust the Drawsize anymore.
I can change the Size-Value with the Slider, but the “Stroke-Circle” always stays the same Size and its of white color (i thought it should be red).
Could it be that i accidentally “locked” the Draw-Size with a Key-Command? But why wouldn’ t it be set back to normal behavior when i restart or “initialize” ZBrush?
Thanks in Advance for the Help
Greetz from Switzerland,
jahkri
This is a known issue in ZBrush 4R2. The solution is to put a 3D mesh into Edit mode first. Then the Draw Size will adjust correctly.
See here for more info.
