Iv been having a bit of an issue with the “E enhance Factor/opacity” options. There pretty much greyed out, and cant be adjusted for when I use reference images.
If I create a simple mesh like a sphere and then (in the draw tab) pick a view in which I want my image to show, ALL the options work fine. But… If I save that tool for later, close out of zbrush, open zbrush again and then load that same tool (or any other tool for that matter) and try to use the Image options in the Draw tab, those options wont work, there greyed out.
I at least get the options back to choose which image side’s to use, but that’s only after I click on the button “snap shot to grid” which makes images of your present mesh and sets up an image plane out of them to use.
But in the end, the “E enhance Factor/opacity” options that allow you to see through your mesh so you can see your reference better are still greyed out.
any ideas?
