Doing The ZDeco Rock and Roll (added a couple tips for making Picture Frames Z2
All DecoBrush (with 2 new texture tips) - Flat Render (The Mattes and the Frames are not ZBrush)
[img]http://www2.zbrushcentral.com/uploaded_from_zbc/200404/user_image-1083053203sxu.jpg[/img]
Hi Space
Do you know the french expressionist painter Georges Mathieu ?
Pilou
Thanks Philou for the Artist link- bookmarked it :wink:
What is the prog for the “Frames not Zbrush” ?
Pilou
Pilou,
i think it’s the “frames” option from Paint Shop Pro (v7 and up).
Thx
Seems not so bad :slight_smile:
Pilou
Philou- Edwin SI75 is correct it is Paint Shop Pro v7.04- these are default frames some are good some not.
I think frames counld be made with ZBrush (and I might start another post for it).
  1. create a proper ratio for frame size doc in black and in graphics app create white borader (or design)then in ZBrush grab and made3d then edit with the move, scale, etc Ztool and save as a ztool. Then use the doc with white boarder to ZPaint on keeping in mind that the white area will be covered with frame ztool
  2. Starts off like above but when go to paint paint on the Plane3d ztool in a ratio to the frame ratio then mutlimaker them and save as a polymesh3d ztool
    As I have not done this it may not work so your thoughts on how to do are welcome
    BTW a ratio ZScript for doc and the Plane3D ztool would help- if one can be made (in other words I do not know if it can be done as a zscript)
Created a 3d frame from one of the tips above and used the first image as a texture
Hi Space
There was a thread about making frame with Zb :slight_smile:
Alas the Up Menu Images are now reduce numbers so I must refind it !
For Patient see these old tut :rolleyes:
Tut 1
Tut 2
Tut 3 :slight_smile:
The solution was to use the SweepProfil !
So be patient for link of the thread !
Pilou
OK I refound it !
Look page down the post of Jaycephus !
Perfect 3D frames in Zbrush :cool:
Have happy Zbrushing!
Pilou
Thanks for the links Pilou :wink:
