Does anyone know if zbrushcore can do stencils? I know it doesn’t have spotlight, but I could probably get by with stencils if it has them…
Thanks!
Sam
Thanks!
Sam
It doesn’t have stencils but it does have masking. You can import a grayscale image and use it to mask out part of your model.
Is that just using it as an alpha? Or is it a separate feature? If so, where can I find it? I need something like stencil in that I can maintain it’s position (not a brush).
Thanks,
Sam
You’d have to make your own stencils and use them as alphas with the masking brush.
gotcha. thanks for the info,
Sam
Yes, you can’t fix the position in the same way as using Spotlight or Stencils.
