Display lower polyframe on a reconstruct object
I often use recontracted geometry.
I would like to display the new lowest polyframe on the highest level.
The thing is zbrush still uses the medium res polyframe for the wire (before reconstruct), not the new retrieved one…
Is there a way to force zbrush to the the real lowest polyframe?
i was wondering the same thing just yesterday, somehow eventually i got the lower frame to show up, don’t remember if i cloned my tool or what. i even got some very weird polyframe things happening later, like subd cages you see in other apps where lines just stop.
If you export an OBJ at the lowest level, then re-import the same OBJ, it will work.
What if you go to the lowest division level (base mesh) and turn off then turn on polyframe. Polyframe should show the base division wireframe as you travel back up to higher subD levels.
okay for some reason i cannot get this to work anymore, i had a model at 6th level, did a reconstruct, and as normal the polyframe got destroyed, so i did the export, then import, turned on frame and its still broken, maybe i’m forgetting something.
doh, weird, i just deleted the layers i had and presto it showed up.hmm.
