Hey guys,
I’m relatively new to zBrush so this is my first time trying to export a displacement map. I used some guidelines from the internet for export settings and all through the multimap exporter. However the map exported black and red. Is that normal? The detail is there when I look at it in Photoshop, but I’ve never seen a red displacement map before. I think this may be tied to the issues I’m having when I try to import it into Mari (lots of artifacts and missing detail), but I’m not sure so I wanted to ask here first. I also tried using the built in zbrush displacement map exporter which did keep the map black and white, but a lot of detail was missing from it. Any advice is much appreciated.
Thank you
