That’s a bug, so thanks for pointing that out. Please try the attached file to see that it fixes the problem. To install:
- Unzip the file to your Desktop.
- Open any folder created by the unzipping and locate the ImagePlane_2018.zsc file.
- Copy the ImagePlane_2018.zsc to the ZBrushOSX 2018/ZStartup/ZPlugs64 folder making sure you replace the file of the same name that is already there.
- Restart ZBrush.
The Load Image button should now work as intended.
On what you are trying to do:
The Load Image button is part of the Image Plane plugin that is described here:
http://docs.pixologic.com/user-guide/zbrush-plugins/image-plane/
It’s mostly used for using reference images behind a model and the Load Image button sets up an image in a way that suits that purpose.
To simply get an image into ZBrush you would use the Import button at the top of the Texture palette. How you get the image on to your model will depend on what you are intending to do with your model. If you say a bit more about that then I’ll help with the next stage.
ImagePlane_2018.zip (10.1 KB)ImagePlane_2018.zip (10.1 KB)
