hi there,
Everything is in the Title.
The DefaultZcript got called again (first time for startup as expected) when I toggle the Zscript:Hide Zcript button (e.g “H”).
Any solution to avoid this issue?
here is the code
[RoutineDef, setup,
[IShowActions,0]
[IConfig,4.5]
[IPress,Material:BasicMaterial]
[ISet,Draw:Z Intensity,66]
[note, "setup intialized successfully",,.5]
[If,[MemGetSize,StartupMem],
[RoutineCall, setup] ,
[MVarDef,StartupMem,1]
[pd]
[EDIT] Actually the method is called everytime the UI changes.
cheers
Bruce
