Default ZScript-Document Double Res
Hi, I’m using the Activates Multithreading at startup code in my default ZScript.
Is it possible to activate Document/ Double Resolution at startup also. If so does anyone have an example of the code I can use to do this?
Thanks,
Ben
There’s no need to. Simply create a document of the desired size and save it to the ZStartup folder as StartupDocument.ZBR.
You can also give it as many layers as you’d like, specific rendering settings, and even lighting.
Excellent, thanks for that aurick.
Ben
